| Jack in the Box by Bare Metal Garage | |
+14woody chevy356 twenty Madmath cedric raph rats chouchou74 shifter's Elgrande hot import andy4rrrr Fab's mika L-Jack 18 participants |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Sam 11 Jan - 15:06 | |
![L-Jack](https://2img.net/u/2915/22/24/66/avatars/1348-88.jpg)
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 20 Jan - 20:50 | |
| Après une petite pause en ce début d'année, je reprend mon projet ! Aujourd'hui, démontage de la caisse et de l'ensemble moteur/boite pour travailler plus facilement au châssis (remesures des diagonales car j'avais un doute, mais tout va bien ouf), et placement de la traverse av pour la fixation de lame av. Fini le kmember. Puis création des tirants à partir de tubes ovals (si si, ça existe....) Place aux photos! ![Jack in the Box by Bare Metal Garage - Page 2 Img_6752](https://i.servimg.com/u/f55/17/98/13/28/img_6752.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6753](https://i.servimg.com/u/f55/17/98/13/28/img_6753.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6754](https://i.servimg.com/u/f55/17/98/13/28/img_6754.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6755](https://i.servimg.com/u/f55/17/98/13/28/img_6755.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6756](https://i.servimg.com/u/f55/17/98/13/28/img_6756.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6757](https://i.servimg.com/u/f55/17/98/13/28/img_6757.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6758](https://i.servimg.com/u/f55/17/98/13/28/img_6758.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6759](https://i.servimg.com/u/f55/17/98/13/28/img_6759.jpg) Et voila pour l'instant. | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 20 Jan - 20:57 | |
| tu bosse plus vite tout seul.... tu parles moins peu etre.... | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 20 Jan - 21:14 | |
| cool ! mais la fixation de whisbone me fait peur | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 20 Jan - 21:17 | |
| Euh oui Raph, mais j'aime bien parler aussi ! | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 20 Jan - 21:29 | |
| N'aie pas peur Mika, c'était un petit montage provisoire pour vérifier l'angle de chasse.
J'ai demandé au père d'un copain de me tourner 2 pièces plus costaudes et plus précises. Mais merci quand même de te préoccuper de ma sécurité !
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 20 Jan - 21:35 | |
| bin oui on sait jamais la peur n’évite pas le danger ![Mr. Green](https://2img.net/i/fa/i/smiles/icon_mrgreen.png) mais on n'est jamais trop prudent | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Ven 24 Jan - 19:04 | |
| Encore un grand pas de franchi! Aujourd'hui j'ai monté (à blanc ) le train av avec le support de lames ,( posées directement sur l'essieux) pour voir ce que ça donne avec ces lames, et ça marche !!!! C'était pas gagné car j'utilise 1 seul paquet de lames "d'origines" du train av Simca qui lui en utilise "normalement" 2, et avec un moteur plus petit et plus léger. La traverse maison: ![Jack in the Box by Bare Metal Garage - Page 2 Img_6760](https://i.servimg.com/u/f55/17/98/13/28/img_6760.jpg) J'utilise du tube de 40x60mm, ce qui permet de faire une découpe pour" l'emboiter" et répartir l'effort sur la traverse. Des renforts sont prévus. ![Jack in the Box by Bare Metal Garage - Page 2 Img_6761](https://i.servimg.com/u/f55/17/98/13/28/img_6761.jpg) Petite vue d'ensemble, il y à des blocs en bois sous les roues pour compenser la différence de hauteur avec les 21" qu'elle aura plus tard (quand les entretoises seront faites) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6810](https://i.servimg.com/u/f55/17/98/13/28/img_6810.jpg) | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Ven 31 Jan - 21:12 | |
| Faire et défaire.... Retour de la "caisse" sur le châssis pour continuer le dos. D'abord tarauder les trous pour fixer les pieds de montant av de portes ![Jack in the Box by Bare Metal Garage - Page 2 Img_6762](https://i.servimg.com/u/f55/17/98/13/28/img_6762.jpg) Soudure du dos( constitué des 2 vieilles portes de peugeot) au toit (constitué du coffre de ford). ![Jack in the Box by Bare Metal Garage - Page 2 Img_6811](https://i.servimg.com/u/f55/17/98/13/28/img_6811.jpg) Fabrication des renforts pour rigidifier le dos.(x quatre) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6813](https://i.servimg.com/u/f55/17/98/13/28/img_6813.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6812](https://i.servimg.com/u/f55/17/98/13/28/img_6812.jpg) Le premier en place, base soudée sur un plat boulonné à un renfort lui-même soudé à la traverse arr. ![Jack in the Box by Bare Metal Garage - Page 2 Img_6814](https://i.servimg.com/u/f55/17/98/13/28/img_6814.jpg) Y à plus qu'a continuer ! | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 3 Fév - 17:09 | |
| Et bien j'ai continué ! Mais d'abord, un peu de barbouille à l'antirouille, après on saura plus écarter les toles et se sera trop tard. ![Jack in the Box by Bare Metal Garage - Page 2 Img_6815](https://i.servimg.com/u/f55/17/98/13/28/img_6815.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6816](https://i.servimg.com/u/f55/17/98/13/28/img_6816.jpg) Maintenant le dos tien, mais il faut encore boucher les coins, sans roue anglaise...vais essayer un truc , on verra bien si je garde ,ou pas ![Jack in the Box by Bare Metal Garage - Page 2 Img_6817](https://i.servimg.com/u/f55/17/98/13/28/img_6817.jpg) Ma cintreuse : un bout de tube, et des bras ![Jack in the Box by Bare Metal Garage - Page 2 Img_6818](https://i.servimg.com/u/f55/17/98/13/28/img_6818.jpg) Quelques traits de disqueuse pour pouvoir plier la tôle et suivre la courbure du montant de porte ![Jack in the Box by Bare Metal Garage - Page 2 Img_6819](https://i.servimg.com/u/f55/17/98/13/28/img_6819.jpg) Pointage par l'intérieur pour maintenir le tout, ensuite, faudra encore couper les chevauchements de tôles et marteler pour donner la bonne forme...c'est pas encore fini tout ça ![Jack in the Box by Bare Metal Garage - Page 2 Img_6820](https://i.servimg.com/u/f55/17/98/13/28/img_6820.jpg) Bientôt la suite ! | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Ven 7 Fév - 17:35 | |
![cedric](https://2img.net/u/2915/22/24/66/avatars/1-71.jpg)
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 10 Fév - 20:36 | |
| Perso Jack, j'attend encore un peu avant de donner mes avis car j'ai un peu de mal à voir le résultat final. | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 10 Fév - 22:16 | |
| Je comprends Cedric , ça va être "space", petit, très court, un peu comme un gros jouet, et j'espère pas trop moche...et comme j'ai déja dis lors de la présentation: différent, tendance nostalgia . C'était ça l'idée de départ: ![Jack in the Box by Bare Metal Garage - Page 2 Img_6410](https://i.servimg.com/u/f55/17/98/13/28/img_6410.jpg) Voici le travail du jour. Toujours la suite du coin arr gauche ![Jack in the Box by Bare Metal Garage - Page 2 Img_6825](https://i.servimg.com/u/f55/17/98/13/28/img_6825.jpg) Ensuite, démontage du boitier de direction ![Jack in the Box by Bare Metal Garage - Page 2 Img_6826](https://i.servimg.com/u/f55/17/98/13/28/img_6826.jpg) Il y à beaucoup de billes là dedans... Fabrication du support ![Jack in the Box by Bare Metal Garage - Page 2 Img_6827](https://i.servimg.com/u/f55/17/98/13/28/img_6827.jpg) pose en place afin de vérifier l'emplacement futur du volant ![Jack in the Box by Bare Metal Garage - Page 2 Img_6828](https://i.servimg.com/u/f55/17/98/13/28/img_6828.jpg) et avec le tableau de bord ![Jack in the Box by Bare Metal Garage - Page 2 Img_6829](https://i.servimg.com/u/f55/17/98/13/28/img_6829.jpg) | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Mar 11 Fév - 7:54 | |
| Ton boitier va torcher ta caisse dans tous les sens... tu n'imagines pas la force que ça a une direction. Il te faudra des renforts beaucoup plus costauds | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Mar 11 Fév - 18:38 | |
| Salut Madmath, je vais renforcer la structure avec des triangles dans les coins et raccorder le boitier à la traverse superieure, je pense que ça suffira. Pour l'instant, je ne suis encore qu'à la phase de montage à blanc pour toute l'auto, si tout se passe bien, il n'y aura plus quà tout redémonter pour finir les soudures du dessous et renforcer ce qui devra encore l'être ( châssis, caisse, trains ....) mais ce sera pour plus tard , là j'essaye d'abord d'assembler mes vielles pieces entre elles... Après, je roulerai avec ![bounce](https://2img.net/i/fa/i/smiles/icon_bounce.gif) et si tout se passe toujours bien, et bien, encore démontage complet pour les peintures, ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) pfffff | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Mar 11 Fév - 18:43 | |
| Fais des tests mais pour en avoir fait moi même, je pense que c'est toute la structure de caisse que tu vas devoir renforcer | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Mar 11 Fév - 18:57 | |
| Oui, ça se peut, je verrai bien; mais c'est quand-même pas un v8 devant et la "chose" la plus lourde ce sera Bibi... | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Mer 12 Fév - 8:14 | |
| Y a pas besoin de moteur pour que ta direction vrille tout, un boitier a une force énorme | |
![twenty](https://2img.net/u/2915/22/24/66/avatars/1211-65.jpg)
Nombre de messages : 224 Age : 50 Localisation : in the middle Points : 253 Date d'inscription : 14/04/2012
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Jeu 13 Fév - 15:01 | |
| ça m'impressionne toujours autant. Comme Math ou Raph, avec kedal vous partez dans les délires les plus sains au final. J'ai volontairement oublié 32, car il est partout dans la presse en ce moment celui-là Je suis bluffé par ton taff. Faut vraiment que je me bouge le cul pour avancer sur le mien | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Jeu 13 Fév - 21:17 | |
| Merci pour tes commentaires, ça fait plaisir!
Et toi, t'en est ou? c'est une base sympa que tu as!
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Ven 14 Fév - 13:45 | |
| la coque est finie. Je glane des pièces en ce moment pour continuer tranquillou. En attendant je construis le garage pour tout mettre car je suis à l'étroit Mais je vais reprendre dans 1 petit mois ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Sam 15 Mar - 23:11 | |
| ici aussi L-jack a bien avance..... des photos peu etre mr?? | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 31 Mar - 22:28 | |
| Dos coincé avec le bras droit qui s'engourdi depuis quelques semaines, grrrrr même pour utiliser le pc c'est difficile ! Voici donc les dernières avancées. Refait les points de fixation des lames arr. ![Jack in the Box by Bare Metal Garage - Page 2 Img_6834](https://i.servimg.com/u/f55/17/98/13/28/img_6834.jpg) Fabrication du support de feu arr. ![Jack in the Box by Bare Metal Garage - Page 2 Img_6835](https://i.servimg.com/u/f55/17/98/13/28/img_6835.jpg) Création de la prolongation de moulure de porte qui va "mourir" sur le support de phare arr ![Jack in the Box by Bare Metal Garage - Page 2 Img_6836](https://i.servimg.com/u/f55/17/98/13/28/img_6836.jpg) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6837](https://i.servimg.com/u/f55/17/98/13/28/img_6837.jpg) Petite vue générale avec le coin fini (aussi de tout le b****l dans l'atelier !) ![Jack in the Box by Bare Metal Garage - Page 2 Img_6838](https://i.servimg.com/u/f55/17/98/13/28/img_6838.jpg) La suite plus tard, quand ça ira mieux ![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png) | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage Lun 31 Mar - 23:25 | |
| soigne bien tes cervical tu en aura besoin pour voir la route bonne continuation ps: quelques infiltration bien placée te feront un bien fou ![Twisted Evil](https://2img.net/i/fa/i/smiles/icon_twisted.gif) | |
![Jack in the Box by Bare Metal Garage - Page 2 Empty](https://2img.net/i/empty.gif) | Sujet: Re: Jack in the Box by Bare Metal Garage ![Jack in the Box by Bare Metal Garage - Page 2 Icon_minitime](https://2img.net/i/fa/icon_minitime.gif) | |
