Coffret Collector Zelda Tears of The Kingdom : où l’acheter ?
149.99 €
 V12 Rover Météorit
benhue
Nombre de messages : 1
V12 Rover Météorit Empty
MessageSujet: V12 Rover Météorit   V12 Rover Météorit Icon_minitimeDim 10 Juin - 8:38
Bonjour, je me sépare d'un V12 rover par manque de temps. Je vous laisse les références du moteur pour un projet fou.
Je le vends 2800€
1649cu in 27 litres, (27,000 cc)
Type..60 degree V12, pressure liquid cooled, 4 stroke, 48 valves, geared drive.
Construction...Two-piece Aluminum alloy crankcase.
Cylinders¦ two-piece aluminum alloy cylinder blocks, Hardened steel liners.
Valves¦ Forged Chromium-Nickel tungsten steel valves, 2 inlet valves and 2 sodium cooled exhaust valves per cylinder, (4 valves per cylinder)
Camshaft¦. Single camshaft per bank operates 24 under slung rocker arms with roller followers. Cam driven by bevel gears via inclined shafts.
Crankshaft¦. Forged crankshaft of Nickel-Chromium Molybdenum steel, Nitrated & balanced with fork and blade connecting rods, 7 main bearings, end to end crank lubrication.
Main caps¦ Six bolt mains, 7 Forged Aluminum Main caps, two main studs with two additional traverse cross bolted studs.
Big end bearings¦. Removable steel backed Silver-Lead Indium lined.
Pistons ¦Forged aluminum alloy pistons.
Ignition.......Twin magnetos, twin spark plugs per cylinder.
Power output¦.. 750 bhp at 2500rpm, 1500 ft lb of torque at 1500 rpm, (67 Low Octane fuel) naturally aspirated Meteor spec
Power output¦.2,000 bhp at 25lb boost, (supercharged or Blower)
V12 Rover Météorit
» V8 ROVER
» avis sur le 3.5 rover
» rover v8 3.5 supercharger
» pont rover
» P6 rover V8 3.5L très bon prix
Forum :: Petites annonces :: Autres pièces à vendre-
