bjr
pensez vous que cette manip est fiable?
THIS IS THE INSIDE OF THE TOP OF THE AIR CLEANER,
AFTER REMOVING ALL OLD FILTRATION MATERIAL.
YOUR NEW PAPER FILTER SYSTEM.
WE USED A ROCKHILL #66184 FILTER. YOU CAN ALSO
USE ANY OF THE FOLLOWING:
AC #A432C
FRAM #CA6370
HASTINGS #AF903
MOTORCRAFT #FA1080
NAPA #6184
PUROLATOR #A14380
WIX #46184
THE GAP BETWEEN THE TOP AND BOTTOM HALF IS THE SAME
AS THE ORIGINAL, BEFORE WE GUTTED IT. YOU CAN'T TELL
THE DIFFERENCE BETWEEN THIS AIR CLEANER AND THE
ORIGINAL UNLESS YOU TAKE THE TOP OFF AND PEEK IN. NO
DIRT WILL GET INTO THE CARB. AND THE AIR FLOW SHOULD
BE GREATLY IMPROVED. WHEN IT'S TIME TO CLEAN THE AIR
CLEANER NOW, JUST PULL OUT THE PAPER ONE AND REPLACE IT. NO MORE MESS TO CONTEND WITH LIKE THE
DIRTY OIL BATH CLEANER. WILL PAINT THIS ONE NOW , THEN
REPLACE THE ONE ON THE CAR WITH THIS ONE.
